What to do?
    What to do?
    I blew my F and have been looking for an H but cant get one on my current bugget...And im diying to drive my car again.
    I have an F22a4 block sitting out back, but it has been in the weather with no head and all so there is a bit of surface rust on the cylinder walls and the pistons themselves...The last time I tried I could even turn the crank...
    So should I keep saving up for an H22. Or should I pull the block apart, maybe bore out the cylinders and throw some different pistons in there to up the compression?
    id say either save up for an h22 (its worth it) or just go to your local jy and get a f22 for about 200-300$. maybe even less
    alone in this game . ::My Ride My Way::
      I just decided that if I cant find an H22 soon. Im just going to stay F for a while longer. And work on the suspension and other things. And Get an H22 or keep saving even longer for a J
      Although If I am to go with the F...What would I have to do to use my block?
      Im sure it would need pistons right?
