Headlight issue
    Headlight issue
    Ok guys.
    I have a weird issue, when i turn my lights on, the High beam indicator is ON
    one of the high beam lights is on, and i cant turn it off, unless i turn all of them off. My driver side works, but passenger is dead....any ideas ? right now i unplugged my high beam, because i dont want it on 24/7
    this is a real aggravating problem !
    Members Ride - 1993 Honda Accord EX
    check the grounding block on the drivers side fender side. make sure its getting a good ground. Another thing is that the switch itself might be going bad. try to get one from the JY and try it out.
    Originally posted by Devergote
    A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
      Hmm...the grounding part
      you are probably right, its the thing that is bolted on the side correct ?
        any new ideas guys ?
          So guys,
          I check out my fuse boxes and the like....and groundings, are perfectly on. Today
          my headlights, only one of them works. Its pissing me off that they are working one day, next day again. IDK what i should do ? new bulbs and like
            You did check the little plastic grounding block that a bunch of wires use as a common ground, right?
            Clean the area on the chassis by sanding the metal down a bit and try again.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              yeah man,im thinking its wiring issue, because my headlights are always on high beam, even when disconnected, the hi-beam indicator is still on
