Eletrical prblems
    Eletrical prblems
    My car is doing some weird things like before I start i hear a clicking sound but its not relay this happens when my dumby lights are on,when driving my radio cuts on and off my temp gauge goes to h but no over heating and jumps up and down with when the blinker is turned on and my sensors are working,when I turn my car on i idles at 1500 for 2 seconds then to 1000 then when warm 500 or 400 rpms but runs fine so my timing is good. batt. is good fuses are good and relays are good
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    bump plz:help
    NEW CB
    new
      this kinda problem will probably require someone to see it in person to solve. check all your grounds, also check wherever you or anyone else has hacked up any factory wires.
      spin city
        First check every ground. a few... there's one behind the passenger kick panel, there are three on the motor and the two off the battery. Check the wires and the bolt for corrosion.
        Then if those are fine you can pull one fuse at a time to see if it stops the problems. Then if you pull one and the problem does stop you might have a short or open ground in that circuit/harness. Obviously when you pull a fuse look to see which one it is and expect that not to work.
        -1991 Honda Accord LX H22a-
