Clutch Alignment Tool
    I've seen ACT and Centerforce alignment tools. Can I use these to align my stock clutch?
    http://www.cardomain.com/ride/2418752
    Yes they are all the same.
    I use an actual transmission input shaft to align my clutches.
      I've always (carefully) aligned the driven plate by eye, never had a problem.
      Regards from Oz,
      John.
        ive onced used an accord alignment tool for a Ford ranger clutch job. i had to shave all the splines off the tool and use it as press fit. never had an issue with alignment.
          From what I understand, if you're able to get the tranny on, you're okay to go. I got the tool anyway for $15 on amazon.com. Thanks for the help fellas.
