The coolant pipe that run from the thermostat housing to the water pump, is there a name for it or a name for the o-rings? I need the o-ring that go in to the water pump.
O-ring
why do you need that gasket?
new ones come with that gasket already pressed into it. I really don't recommend reusing a water pump. I don't think you can buy just the gasket.
If need be Permatex sells a certain type of gasket maker called "The Right Stuff," I would put a skin coat of that around the perimeter.
however I 100% don't recommend that.
the pipe is called CONNECTING PIPE
and the O-Ring (#19) is called O-RING (31.2X4.1) (NOK)
EDIT: you can order these parts if needed from http://www.hondaautomotiveparts.com/home.htm
AKA Majestic Honda..OEM Parts-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-1995 Accord EX Wagon Daily Driver
-2012 GMC Canyon V8 4x4
what the hell are you talking about?Originally posted by ExCoupe92 View Postwhy do you need that gasket?
