idle bouncing
    idle bouncing
    okay recently i did an abs delete. then i turnd on the car and the idle started bouncing. when i took out the abs i didnt remove any hoses except one and that was connected to a brake like so i doubt thats it. i cleaned the iacv and tightend down the fitv and played around with the idle adjusting screw. all of this did nothing. i have the cel for the iacv but i dont want to replace it and it not work.
    anyone know what this could be? mayb i need a non abs brake booster and thats whats messing up the vaccuum. idn just a wild guess.
    HELP PLEASE!
    alone in this game . ::My Ride My Way::
    well...its not the iacv...it's doing its job...it is trying to fix the idle...thats why it's bouncing...it sounds like you definitely have a vacuum leak somewhere....what did you remove when you did the ABS delete? and there is no difference between the ABS and Non-ABS booster...but check all your vacuum lines...the best way to do this is to get a can of carberator cleaner or two and spray it around all the vacuum lines, intake gaskets and throttle body areas...if you hear the engine try to die down, you have found the leak...that is the best way I know to check for leaks like that...good luck
    "I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
    ASE Master Automotive Technician
    ASE Master Med/Heavy Truck Technician
    US Navy Electrician
    Contact me if you need help on the side.
    '92 Accord DX (For Sale)
    '01 Civic LX
    '00 Tahoe
    Greatest Rally Video Ever
      my abs took a crap on me so that was my only option infixing my low pedal issue without spending 1600$. ill try that carb cleaner trick.but if its not my iacv then why would the code come on?
        Just because there is a code for a certain component, that doesn't always mean that particular component is bad...it could be something else causing that component to act irratically...I shouldn't have said that the iacv is not the problem...i should have said that it is most likely not the problem...Here is the diagnostic procedure...this might help in your diagnosis
        Page 1
        http://i22.photobucket.com/albums/b3...de14accord.gif
        Page 2
        http://i22.photobucket.com/albums/b3...e14accord2.gif
        Page 3
        http://i22.photobucket.com/albums/b3...e14accord3.gif
        US Navy Electrician
        '01 Civic LX
        '00 Tahoe
          ok i just realized i dont have a little ruber gasket that goes between the plenum and the iacv. could this be causing my idle to b bouncing? if so where can i get one of these gaskets?
            Yes, most probably.
            Honda.
            You could also make a gasket from gasket paper.
            Regards from Oz,
            John.
              Yea you can get it from honda for about a 1.50.
              1992 Accord Wagon (RETIRED)
                hondabond FTW!
                Official CIVICKILLER's members ride thread! http://www.cb7tuner.com/vbb/showthread.php?t=112829
                rock her with the shocker!
