ok so i was driving today and i was behind someone driving very slow, so i went to pass them and as soon as my car down shifted it started to stutter. i came to a stop light and as soon as the idle dropped the car stalled out. finally got it home, checked the spark plugs and they were fouled, replaced them but same thing. the only way to get the car to start is to turn the key and pump the gas then hold the pedal so the idle dosent drop, meantime the car is stuttering hard and exhaust smells like pure fuel. any ideas? (H22) thanks.
to much fuel car wont start
check u FPR
hold a flathead screwdriver to the inyector and place ur ear at the end of it and hear every click (chek for the one thats not clicking
is ur ECU chipped
if not
check o2
knock sensor
if u have a vafc
check connection
and most importantly do u have any CEL?Last edited by PR CB7; 08-14-2008, 07:33 PM.
no my ecu is not chipped but it i do have a vafc and i cant get any cels cause the car wont stay running but when i did get it running i didnt have any cels
BB6 2001 Prelude SH
Originally posted by Makaveli2kDon't be a sissy. Pull out, spit on the tip like they do in the porno's and get back in there.
=p
no egr have block off plate and i havent checked the knock sensor, where is it located?Originally posted by PR CB7 View Postp13 hmmmmmmmmmmmmm
egr valve might be stuck open
knock sensor
BB6 2001 Prelude SH
=p
I went to his house & tested a few things...
1.the voltage of the wires going to the internal coil>>>it was to specs
2.the resistance of the internal coil>>>it was ok but not perfect so I changed it
3.I checked to see if the injectors were clicking evenly>>>they seem like they were
4.I checked the oil>>>it only had like a qourt so I added more
5.I swapped my ignitor for his>>>his works just fine in my motor
6.I did a compression test>>>the results were 210 in all except #3 which had 0 (twice)
7.I swapped my OBD2 fuel pressure regulator for his>>>it didnt solve anything
8.I swapped my rotor for his>>>it didnt solve anything
I noticed that after we changed the internal coil, there was finally spark going to the cyclinders. but after starting it he still had to keep the RPMs high as hell to keep it from dieing.
93 Accord LX Sedan (sold)
Originally posted by Night Wolf View PostI went to his house & tested a few things...
6.I did a compression test>>>the results were 210 in all except #3 which had 0 (twice)7.I swapped my OBD2 fuel pressure regulator for his>>>it didnt solve anything
eeeeeeeeeeeeeeeeeeeeeeehhhhhhhhhhhhhhhhhhhhhhh
compresion on #3=0psi
yeah I told him to try filling that cylinder with air
