My battery every now and then will accumilate too much static in it and wont work. I will go to turn the car on, everything works, and then I go to start it, and it dies, everything goes off. I pop the hood, wiggle the neg. terminal around, and get the static off, and it works fine. I redid my ground wires, but they are much better than stock, and i shaved plenty of metal for the contacts. Should I get some of that battery grease or whatever that is called for it? It did it a few times in FL, but now that im in Michigan, it does it a little more.
Battery Problem
wiggle? is it loose?? those OEM terminal post holders arent that great after a while and will break.
another....most auto stores have a diagnostic free for enging electronics....What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
did u shave too much metal off the contacts so that they fit loose now?
