i just put my new f22a1 motor in and after i start it i have to turn it right back off because it revs up over redline and just keeps climbing so i turn it off because it sounds like it is going to blow itself up. so what do u think the problem is?
motor reving to 5 grand when started
sounds like compression. it seems like it's turning over too easy. try throwing some oil into the cylnders and let it sit for a few hours.. then try starting the engine again.. Honda engines are known to dry out, and lose compression after sitting for a while without running..
if that dosnt solve it , i guess it could be a throttle cable problem.Last edited by dwf137; 10-01-2004, 01:35 AM.
checked trottle, vaccum, and did a self diagnostic test on it and got no cel's
so i thought it might be the iac but since there are no cel's than it can't be that so i don't know what it is
can anyone else help?
is the fast idle vavle part of the iac controller if so can the fast idle valve be bad and not throw a cel or will it have a cel because it is a apart of it of the iac systemkyle turner
[img]june21004[img]
no just keeps doing it. i have only had it on for about 5 min strait tough so it should of warmed up. how many vaccum lines are there. i'm almost positive that i don't have any leaks
the reason i only had it on 5 min is because all i have on it is my header and i know the people we live by don't appreciate it muchkyle turner
[img]june21004[img]
