Non functional Speedometer.
    My speedometer was acting up for quiet a while now. It would sometimes go up and down while I'm in idle not even driving or wouldn't work at all while I am. I was told to change the speedometer sensor which I received a few days ago and installed today. Now it doesn't even work at all anymore. It's not acting up or moving in any way. This same problem causes a check engine when engine braking so it kind of pisses me off. Would anyone know what it could be? Thanks.
    NEW MYRIDE THREAD
    PARTS 4 SALE
    bad speedo itself ?
      I have thought about it but I completely took it LL apart and it looks brand new. The likeliness that a speedometer goes bad is just low. People don't go playing in there but I'll definitely look for another one just to try and make sure.
      NEW MYRIDE THREAD
      PARTS 4 SALE
        probably your VSS (vehicle speed sensor) is gone
        Hold On Not Done Accelerating
        Had One Never Did Again
          I have the same issue. I'll keep an eye on this thread.
          DEVOTE
          FS: Lokuputha's Stuff
            As I said... I changed it already.
            NEW MYRIDE THREAD
            PARTS 4 SALE
              I'll let you know if I figure it out.
              NEW MYRIDE THREAD
              PARTS 4 SALE
                Did you change the gear part, or the switch? And, gauges can stop working, after all, it is a 15 to 18 year old car, things stop working over time
                  What do you mean gear part or switch? All I changed so far in order to try and fix it is the speedometer sensor which includes the electrical and mechanical part. The odd thing is that it was working fine when I bought the car last summer.
                  NEW MYRIDE THREAD
                  PARTS 4 SALE
                    from what you say, its most likely the speedo gauge. pick up a used from the junkyard and give it a shot.
                    the only things i've ever seen go wrong with speedo problems was the VSS and the gauge.
                    '93 EX-R 5spd
                      make sure that you didn't push out any pins when plugging in the sensor
                        Ok.... I ran a check engine diagnose since I told you guys whenever the speedometer doesn't work and I sow the car down, the check engine light goes on. According to the code, it is in fact the speed sensor. However, as you guys already know, I already changed the speed sensor. With the old one it used to work sometimes but now with the "new" one it doesn't. I'm starting to wondering if that new one is even functional. I took my old one apart and it was full of smelly black grease. It literally smelled like shit mixed with oil. I cleaned it up and I'll replace it on Saturday to see if it works. I'll also check for squeeze wires since my fuel gauge didn't work because of one. It might be the case of my speedometer too who knows. All I know is that it is getting annoying. I had all the possible electrical problems with my car. I changed the driver side window master already, my distributor, now my speed sensor and I still have my brake light that goes on due to a bad connection somewhere at the taillights and my fuel gauge only works when I pull the dash light intensity button out and straighten the wires Anyway that's all just bad connection. What I really want to fix is that damn speedometer.
                        NEW MYRIDE THREAD
                        PARTS 4 SALE
                          There should be a fuse underneath your dashboard for the vss. Check it.
                            That's something I haven't thought about. It could be... Thanks. I'll try everything I can on Saturday.
                            NEW MYRIDE THREAD
                            PARTS 4 SALE
                              there is a little key looking piece that you are supposed to insert into the VSS sensor, its really easy to lose, maybe it fell out? just throwing up ideas.
