my i've about had it. Ok my car is still over heating on the highway, and sometimes in town. Now peep this. I removed my thermostat to see if it was bad this was a week ago. Topped off my coolant and drove like normal. last night car was running to the H but when i stopped it went down. So today i put water in the reserve topped off with water and bleed the system at work. A funny thing happened the coolant stopped coming out of the bleeder valve. I could sqeeze the bottom radiator hose and see a little coolant move on the valve but the stream never came(no homo) what gives. I thought when you bleed a system you let it run until the bleeder valve streams constant with coolant. Do you think air is still in the system, or what.
