1. my gas door doesn't open by pulling the little gas lever. i replaced the black thing that is controlled by the cable allready (my old one was broken) and still doesn't open. my uncle says there should be some sort of spring to bounce it out but we couldn't find anything
i gotta stick my key everytime i pump gas! and its tearing up my paint.
2. my dizzy is kinda like leaking oil from the lower front screw. it's just accumulates right under the screw and leaks down into the tranny and to the floor. i put a little of that gasket glue or w/e on the screw and screwed it in. but like 2 or 3 weeks after it after leaking again. so can i use some sort of Teflon tape? idk something. I've replaced the screws, just in case i was stripped but it's not. and when i remove the screw it DOES have some oil on it which probably is where it leaks from
this is the place it's leaking just in case anyone doesn't know
and it's not the valve cover! vc gasket just replaced cuz it did leak a bit and put rtv sealant on it on that one corner where most vc's leak from.
Anyone shed some light ?
i gotta stick my key everytime i pump gas! and its tearing up my paint.2. my dizzy is kinda like leaking oil from the lower front screw. it's just accumulates right under the screw and leaks down into the tranny and to the floor. i put a little of that gasket glue or w/e on the screw and screwed it in. but like 2 or 3 weeks after it after leaking again. so can i use some sort of Teflon tape? idk something. I've replaced the screws, just in case i was stripped but it's not. and when i remove the screw it DOES have some oil on it which probably is where it leaks from
