i have a 93 dx, with a f22b1, and it went into the shop for an intake manifold gasket.. because wenever you spray carb cleaner around where the head meets the intake manifold, the engine idle dips down indicating a vacuum leak.. the intake manifold gasket was assumed to be the problem... now that he has pulled the manifold off.. he says its because its a 97 head with a 93 manifold.... can this be the problem? they lined up well as far as i knew...
leave your input please....
