high pitched 'vibration' noise associated with hard accleration. which also has loss of power is accompanied, with car hesitation, dont know what it would be.... fizz u mah nizz0 on this one =)
they checked the CAT they said its not that.. the heatshield seems tight as hell i punched it and tried to move it and it doesnt budge... itsa very annoying sound, i think it might be the tranny but i dunno... its ahrd to describe the sound.... not paranoid. my bros like dont accel fast it sounds like shit.. i dunno wtf it is.
well i had the timing belt changed i believe 2 years ago when my dad had it tuned up... i think they changed that stuff.. i just had it in.. you think they'd know to check that? even if they were looking at exhaust and fixed a missing ring on the intake.. acrtually remove it because i wanted more noise from less restriction to airbox. but it sounded *** after a while..
if its a high pitched squeeling sound, check the alternator belt. my belt was getting old and would slip a little every now and then, causing an annoying high pitched tone. i didnt notice if it hurt performance. i only heard it happening while i was stopped, mostly when i first started the car in the morning.
Originally posted by xplode
well.. i dont think its that because it dont happen after first gear...
Change the belts yourself and save your ass a fuck load of money....simple...the easy way is to first pull out the power steering,take that belt off then take out tha alternator. now get below the car and take off the plastic bullshit so you can see your crank pulley. it helps to have a friend so that one person is wrapping the belt around the crank and the other is wrapping it around the alternator,a/c. then tighten the alternator back up. and do the same for the power steering. i know my instructions blow but i think you should get the idea.Last edited by lilchubbz05; 10-26-2003, 09:40 AM.18" ADR RPM's w/ 215/35/18 Nantang'z. KYB GR-2 strutz/shockz. Arospeed Coilovers,Aem short ram intake,ractive muffler w/ custom cat-bacc,pilot rear upper strut bar,pilot rear lower tie bar,ractive front upper strut bar,and Msd wirez, NGK plugz,Chikara hedder w/ header wrap,Unorthodox pullies.
Future Plans.....
5 spd swap
Exospeed stage 2 cams
SAFC
MSD SCI Ignition
