code 4 tcu
    code 4 tcu
    so im throwing a code 4 tcu its a vss code anyone else have this prob??? and what did you do to fix it..............
    Simple , replace the VSS
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      is your speedo working?
        already did
          no its not
            4-Vehicle Speed Sensor open or shorted - No signal from speedometer
              so i messed with the wiring and figured out that the cause of this code was a bad ground caused by a broken/bent ground pin
              hope this helps someone else
                so once again code 4.... changed the vss and didnt work from what i know it is a good vss.
                so another question i would have can you change the internals to make a good one?
                and is there a way to check it
                  i am having this same problem my speedometer isnt working and i have a blinking d4 light and the code is for the vss as well and i replaced it and it still isnt working. what wires could i check to see if they are bad.
                    im in the same boat i know it only has 3 wires black orange yellow and i have power and ground from the correct colors..
                    i even went as far as to change the speedo but still nothing
                      so i checked the orange wire on the cluster and im supposed to have power when the wheels spin right?
                        Sounds like to me its time to break out the volt meter. I dont know if its possible but I have heard the gear inside the little VSS housing can break and you will have to break open the tranny to replace the gear. I am sure you just have a simple wiring issue.
                          yea i did and nothing... im gonna check the wires ar the vss... does anyone know what reading i should get??
                            continuity between black and body ground
                            with ignition switch ON, battery voltage at yellow wire
                            5v reference voltage should be at orange terminal and body ground
                              so i have 12+ volts at both yellow and orange wires
