Ignition problem
    Ignition problem
    Okay, so the ignition is shot. The car won't stay running. I know it isnt the plugs or wires because those were recently replaced and in working order. Plus, I noticed the gauge cluster acting funky before it all happened. What do I look for so I know if it is just the cylinder or not.
    ProjectParty.net
    Putting an end to the question, "What's going on tonight?"
    "This generation has this universal sense of failure" - Kurt D. Cobain
    CLUB 1320
    My FOR SALE thread...buy my ish
    Okay now the car wont start what-so-ever. Whats wrong with my car? IK also noticed that when the key is turned half way the radio and AC come on, but the car doesn't run.
    ProjectParty.net
    CLUB 1320
      Possibly one fo your sensors inside your dizzy.
      FS: BNIB MFactory FD $650, PM me.
        Not to sound stupid but what is a dizzy?
        ProjectParty.net
        CLUB 1320
          Look at your valve cover...follow the spark plug wires, you'll see they all lead to the Distributor cover/cap-the whole mechanism from the cap, everything inside-crank/TDC sensor, Ignitor, Coil(if internal), rotor button, etc, to where the it connects to the cam shaft is the Distributor. It basically just distributes the spark to the cylinders...
          Jay
          Hittin Switches - Draggin XhaustAlways Under Construction
            LOL all ya hadda say was the distributer and I woulda been straight..lol Thanks for the clearification though
            ProjectParty.net
            CLUB 1320
              ha...my bad...I thought you really werent sure. I guess we should be more clearer when using shortened terms.
              Jay
                Got it fixed today. Ended up being the Ignition switch....thank god it wasn't the cylinder..wheeew
                Thanks again for all the help!
                ProjectParty.net
                CLUB 1320
                  Yea...we didnt help really, you already knew the problem and solution.
                  Jay
                    Jay
                    Well technically it was this forums Search feature that gave me the confidence i needed to make the decision of what it really was and go ahead and fix it. So, I thank you again
                    ProjectParty.net
                    CLUB 1320
