gas smell plus corroded line
    today on my way home i just about passed out from the smell of gas, not that im complaining but 93 isnt exactly cheap, i took a look under the car and found a leak coming from a shield in front of the rear wheel on the drivers side, i took off the shield to find this...
    any ideas what it is? if so is this a dealership fix or what?
    OHIO CB7'S #11
    SOLD
    Members Ride DevlTuning
    bump, someone knows this
    OHIO CB7'S #11
    SOLD
      it a $100 high compression line from honda, the 2 steel lines coming down the tank are $32 and they come as a pair. both require you to drop the tank so grab some new gas straps while your at it and a can of PB blaster.
      Mine looks identical, except the 2 steel lines are broken thanks to dumbshits @ SEARS!... those assholes slipped the wrench on the toe adjuster and broke my lines with thier fist. i pull out and notice gas leaking under my car, which had been in a garage every night with no leaks... they locked up shop and wouldn't let me in the next day they said anything could have caused it.
      EDIT: Here ya go, its #024, and the 2 smaller lines i refered to are #026 http://www.hondaautomotiveparts.com/...gry5=FUEL+TANK
      From my research it would be cheaper to get Banjo-to-AN adapters and run stainless line in its place.
      DOUBLE EDIT: just realized your an ohio cb7.... i feel your pain
      Engines hate me... thats why they commit suicide
        those lines like to go bad, especially at that junction.
        this happened to a friend of mine who was looking for a cheap solution, so i ran a rubber fuel line all the way from the rubber line leading from the pump / junction you have pictured, all the way up to the rubber line at the fuel rail. with a cheap inline fuel filter along the way. used two barbed couplers.
        < $20, just dont bottom out on something that would cut a rubber line :P helps if you stuff it up against the original fuel/brake lines, theres room for it, plus you can add a ton of zipties along the way.
          it happened to me also...i went to the jy and bought the whole line that rusted line is connected to the fuel filter..... its kinda easy to replace
          You Can Catch me Ridin In My CB Eyes On The Rearview Lookin For The Police
            Hmm a Jy wut was the condition i'm curious. I've been think of grabbing a fuel pump from one that came in running. OEM = $$$$$
            Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
            CLICK THE PIC
