If anyone with a helms, or a complete electronic copy could help me out by posting or emailing me this brake circuit diagram, i would really appriciate it. So I can do some trouble shooting.
Ive downloaded several manuals from online sources, honda hook up, icelord. and they are both missing the pages I need. I believe its 16-180ish?
anyways been having troubles with my brakes, if anyone cares to chime in. Couple heads are better than one..
Tested my relay boxes on my wifes accord, they check out. Replaced the brake switch on the pedal because the white part was loose, still a no go. I still need to jump the pins on the plug to see if that makes my lights come on.
All bulbs are good.
I checked voltage from the ground on each one of the main sockets to the + pins on the socket and I get 11.xx volts on one, and .18 volts on the other pin. Both sockets have the same reading. This is with the car off and the parking lights on.
Thanks for helping. Tomorow im going to swap out the pig tails from my wifes accord to mine, to see if for some weird reason its the pig tails.
All bulbs are good.
