Wet dizzy
    Wet dizzy
    So i think i got my dizzy wet when i Power washed under the hood a few days ago.Its been running ruff under 2gs and then backfires and runs fine for a bit.Then it looses all power and backfires again, and it sounds like out the intake, but i could be wrong. Any ideas? could i just ake the dizzy apart and clean it?
    90 Panda DX F22A6
    check the inside of the cap. also check to see if your plug wires are shorting
      everything is fine, and not wet. I wired a pusg-button switch to my ECU, and the code that comes up is a O, which is the o2 sensor.But would it fail b/c i wshed under the hood? can i clean it? i recently X-out the flex pipe and had my exhaust welded, could this cause it?
      The CEL light just comes on and stays on, thats a code 1 right?
      90 Panda DX F22A6
        Sounds like you need to check your code definitions. Here's the DIY: http://www.cb7tuner.com/vbb/showthre...&highlight=CEL
        Code 0 is bad ecu, and the light would not come on. Code 1 would be one fast blink, pause for about 3 seconds, and then a fast blink again, repeated forever.
        Is there oxidation on the contacts inside the cap? You should pull it off and take some sand paper ( or a knife, or a flat head screwdriver) to the contacts and just rough them up so you can see shiny metal. Also check the contact on the rotor. My guess is that the water got in and rusted them up, which will kill your car fast.
        1992 Prelude S w/swapped H22A
          well when i check the code the cel comes on and stays on. Im gonna try cleaning the contacts tho.
          90 Panda DX F22A6
