I was driving down the highway, and everything seemed perfectly fine. Traffic was starting to speed up, so I pushed the clutch in to shift. I try shifting, the gear shifter won't shift and makes a grinding noise. I figured I hadn't pushed the clutch in enough, but it was down all the way. I figure "ok, I'll try again" so I take my foot off the clutch... and the clutch stays pressed to the floor. Thankfully I had enough momentum to get to an exit ramp. I called my friend, he told me to shut the car off, shift it into second, then start it (and it worked) so I managed to limp back to the office building I work at. Thankfully I'm in a building with lights, power, etc., so I'm okay for the moment, but I need to figure out what's wrong with my car. I'm not going to ask anyone to drive up here to get me when the temp is dropping to 28 or lower and the roads are starting to ice, and if worse comes to worse I can always take an ambulance out to get food and what not, but I'd like to figure out if there might be anything I can do short of getting it towed as I'll be stuck at work for a while. I can manually pull the pedal out, but as soon as I let go it just sinks all the way back to the floor. Any ideas?
PS I'm about to just sell this car... *sigh*. I love it but it's just been one problem after another.
