Fuel Pressure Setting
    I have a 93 accord with JDM H22 and was wondering how high should i set the fuel pressure b/c i am getting a fuel pressure regulator. I dont have injectors(yet) and was just wondering how much i should set the fuel pressure at with the stock injectors. Yes, i do have an aftermarket fuel pump. So if anybody knows what would be the best setting please let me know. I was thinking about setting at 45-50 since 35-40 is stock correct or would that be too much. Any info will help thanks.
    if u still have a basically stock setup, go with a stock fuel pressure setting....if you have significant mods...then bump it up some
      About 42 psi at idle with the vacum line connected is good.
        What exactly is the stock setting? Just so i can know for future references. Thanks.
          According to the service manual at idle with the vacuum hose disconnected should be between 33-40 psi. I normally set them around 42, It gives the injectors alittle more fuel behind them giving them a nice spary pattern.
