Emergency BRAKE Strength?
    Is it possible to i guess tighten the emergency break or something so it holds stonger. Ive want to make it so if i ever pull it while driving it will actually lock up the tires. yeah it probably sounds stupid me wanting to do this but i do. When i have pulled it while driving it always slowly slows me down. I want it to actually lock up the tires.
    what can i do to the break to make it lock up the tires?
    Pull harder.
    wat?
      Originally posted by C91BLX7 View Post
      Pull harder.
      ha ive tried but it never works for me. it will only do it if im goin under 5 mph. any higher and it never works
        shorten the cables, it should only be a certain amount of clicks
        just be sure the brake isn't applied when you let off, that would be too short
          If you have drum brakes they probably need to be adjusted.
          wat?
            ok i get the first part but the second is kind of confusing me? could you explain a little more?
              after you've adjusted the cables, make sure the rear wheels still spin freely with the ebrake off. If they are locked then you made the ebrake cables too short
                oh aight cool. thanks
                  rear discs lock them up real quick.
                    how do you adjust the rear drums
                      x2
                        take u ebarke cover thing off and there is a bolt come off ur ebark tighten it
                        The Race Car
                          No.
                          You adjust your drums by turning the adjuster with a flat head.
                          wat?
                            Originally posted by Ludacris - "Act A Fool"
                            DRAH! 2 Fast...
                            DRAH! 2 Furious...
                            I'M TOO FAST FOR Y'ALL MAYN!
                            Sorry, I had to get that out.
                            Is there a specific reason you're wanting to do this?
                            It's very dangerous, as you can EASILY lose control of the car while doing this.
                            You can damage the car, hurt yourself, or even worse... hurt someone else.
                            Not to mention, it will cause premature wear on your rear brakes.
                              i see there is a vid there to show how to adjust rear brakes, i'll just add that once they are adjusted properly you will find the e-brake will probably be ok. the main rear brake adjustment has to be good otherwise the e-brake will be loose.
                              96 Accord SiR driveline installed. CF2 donar
