So my car is overheating and i know i need a coolant flush but what can i do until then to make it run cooler?
Band aides for overheating
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.Tags: None
put some radiator fluid in for now as you might be low.
blast the heater constantly as that turns on your heater fan and pushes heat from the engine bay into your cabin.
Remove your front grill for more airflow into the engine?
Get a coolant flush? It's seriously a white knob and a removal of a radiator cap away from being drained and filled.Last edited by ikayto; 12-02-2008, 06:49 PM.
even though it is more work that just flushing the radiator but i would just remove the thermostat, replace the seal bolt back up the thermostat housing and fill whatever fluid was lost with water, that plus keeping your heater on with your windows down will keep it under hot
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
replace the t-state
member ride thread
DIVULGE MOTORSPORTS
I already blast the heat with the windows down but it overheats when im stopped after the cars been running for more than 10 mins.
If you cheap out now you will be spending much more when you do more damage. Do the fans kick on... Did you test the thermostat?Originally posted by J3wman View PostI already blast the heat with the windows down but it overheats when im stopped after the cars been running for more than 10 mins.
Change T-stat and flush it really good. Could throw and additive in it to if you wanted. In the meanwhile turn the heat only and cruise with the windows down, also the removing grill sounds like a good idea too.
"The Turtle"
DD/Trail Rig/Mud Bug
Removing the grill won't do anything.Originally posted by 93F22A6 View PostChange T-stat and flush it really good. Could throw and additive in it to if you wanted. In the meanwhile turn the heat only and cruise with the windows down, also the removing grill sounds like a good idea too.wat?
