M/T problems i think.... need help
    Ok so the other day i was driving my car to my uncles and when i went to turn into his drivedrive way which has a hill... i down shifted to seconed and what felft like the wheels started bounching and stuggling to get up the hill so i down shifted to first to try to make it did the same thing figured out the tires were locking up... running the rick of more damage i put it into reverse moves fine in reverse noticed oil coming out of the tranny but no cracks in it i thing the leak was due to the axle not having a clip and popped out during all the hopping... any suggestions on whats wrong with the car???
    Engine:
    stock F22A4
    Cold Air Intake
    2.5in Exaust No Cat toTip
    Interior:
    Short Shifter
    Exterior:
    5% tint all the way around
    15in gun metal with crome lip rims
    DIY jdm black headlights
    Future Mods:
    DSM Turbo
    with no clip on the axle....that would cause the bouncing feeling as it worked its way out under load. check your fluid level and get your axle replaced/fixed. sounds like you might have pulled the joint apart.
    Retired 1990 Accord LX Coupe
    Project 240SX
      so my clutch and transmission are ok.... ill replace the axle and put fluid in it tomorrow and see if that fixes it
      Engine:
      stock F22A4
      Cold Air Intake
      Interior:
      Short Shifter
      Exterior:
      Future Mods:
      DSM Turbo
        mine was doing the same thing and then i tried to leave a stop and something popped and then my tranny sounded like it had a bunch of marbles in it and was spilling out fluid but the same thing goes fine in reverse but dont like to move in first or second
        http://www.myspace.com/alliance_nwracing
        cb7 NOW FOR SALE!!!
          update i found out whats wrong with it the tranny has a golfball size hole in the bottom.... still trying to figure out what caused the hole
          Engine:
          stock F22A4
          Cold Air Intake
          Interior:
          Short Shifter
          Exterior:
          Future Mods:
          DSM Turbo
            Well... do you play golf? Sorry man, couldnt resist, hope you solve your problem soon, good luck!
            My song of the week (or till I change it): Snow Patrol - Take Back The City
