0w40?
    0w40?
    has anybody here heard of this type of motor oil before?
    my uncle works for exxon and he says that it is what they put in the new vipers, corvettes etc. i was wondering if anybody has tried this in an accord?
    Viper oil does not equal VIPER PERFORMANCE.
    Stick with 10w30 if you car has under 75k. miles.
    and i prefer 10w40 for 75 or 100 and above.
    Noobie my ASS.
      i use 10w30 all year round and i burn a bit of oil so i was thinking of going to 10w40 all year round because maybe the thicker weight oil would burn slower? i dont know just a thought.
        i have a f22a6 with 159xxx miles on it
          yeah, keep it w/10w30.. put the 0w40 in your car, and it wont run as efficiently.
            Actually with a lighter weight oil your engine will have less drag from the oil and will turn more easily (no, not bs). The problem is, the tolerances are pretty large on a well broken in engine so that means the 0W-40 will make it past the rings and other seals much more easily.
            I think the 7th gen Accords spec 0W-30 for the 4 bangers.....I think
              at 160,000 miles you should DEFF. be on 10w40.
              And yes, if you are burning a little oil, give 10-40 a try. It won't hurt anything, and most likely both of you guy's clearances are fairly larger than "factory".
              I only run 10-30 on newer cars or something with less than 70k or so miles.
              Noobie my ASS.
                lucas oil is the shit.
                  ha. Lucas is the shit.
                  But only if your engine is BADLY worn. That stuff is SUPER thick. I admit it will deff. prolong and engines death, but not good for a healthy engine.
                  On a side note, i use that stuff in my manual tranny, and front and rear diffs in my 4*4 toyota. Gotta love the stuff.
                  Noobie my ASS.
                    You know I've been wondering if I should switch to 10-40. My car has 164K and I've always ran 10-30. My F22a6 doesn't burn or leak an ounce of oil. Gotta love them Hondas!
                    "the J32a2 should be considered one of Honda's masterpieces..." Honda Tuning, July 2006
                      what? our cars say to only use 5w-30! thats what the haynes and he car manual say. why is everyone using 10w-40? maybe i should switch to 10w-40, any reason no one is using the weight it says to?
                        40 weight is thicker than 30 weight though...
                        it's just a different heat range...
                        I accidentally put 2 quarts of 50w in my F22A1 once a long ass time ago when doing an oil change... it felt all sluggish and I couldn't figure out why... did another oil change a bit after that and it felt better... I didn't even notice the old 50w bottles until much later and put 2 and 2 together...
                        RIP Lifsatrip7
                          that weight is for a brand new car.
                          If your car has over 100k miles, the clearances are slightly larger, and your oil should be slightly thicker.
                          If 10-30 isn't burning, then cool.
                          Noobie my ASS.
                            I have 173k+ and still run 5w30, either Castrol or regular Mobil oil and it runs like a top.
                            Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
                            1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
                            2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
                            2008 Ford Escape XLT [bone stock]
                            2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
                              For me.. I just follow instructions on owner's manual..
                              car has 190.xxx miles
                              Unsing 5w-30 100% sync.
                              no leak / no burning oil
                              1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
                              2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
                              3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
                              4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
                              5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
