Alright, completely freaked out now
My drivers side upper ball joint needs replacing, so I'm under there doing the control arm swap and notice something strange about the wheel well. From inside the wheel well you can see where the sheetmetal is starting to be curled away....but just slightly.
So I go to see what it looks like in the engine bay up top and sure enough the spot where the two pieces of sheetmetal are welded has started to separate. Worse, due to the separation the area has started to rust slightly.
Needless to say I'm really worried about what damage is already done. The Kon'is are set to soft, and this is only happening on the drivers side. I'm planning on raising the car on different springs, ajdusting the Koni yellow's to the highest perch and putting thicker bumpstops in. Right now this is the set-up:
17 x 7 wheels
215/45 tires
Ingals anchor-type camber kit set to around -1.5
Neuspeed Race Springs from a 94-97 Accord
Any help is appreciated guys, I'm worried I might have done something real bad
17 x 7 wheels
215/45 tires
