i cant figure out whats wrong with them. sometimes the left one will work but it just dribbles out of it. the right one doesnt work at all. ive looked throught the lines to see if its clogged but i have no idea.
I had this same problem. turned out to be the extension hose right near the drivers side hood hinge. play around with that for a bit and you should be able to get it to work
Also check to make sure your nozzles arent clogged cuz i had that problem and it was fixed cuz i unclogged the nozzles. Just take a pin try to get as much out as you can toss the nozzles in a bottle with soap and water and shake them around, thats how i got mine to work.
My Cb bad, Cb bright and the cops can kiss my Cb lights - I’m gone!
Frost White Member 13 My Ride "Girls are like a new car... lease w/ option to buy"
Mine were clogged as well, and I tried to put them in a bottle. I even used paint thinner. They would unclog for a few days, but then clog up again. I finally gave up and was able to get other ones from another CB7. Those have worked flawlessly.
When I did clean the old ones for the first time a lot of crap came out of them for sure.
i have that problem... mine arent clogged because when the hood is open, they work fine... so i traced the hoses, and it was being pinched by the hood hinges... so i have to relocate the hoses..
i dont think it really bothered me though. for one thing i never let my windshield get that dirty
My washer nozzles were clogged as well from dirt an wax. I used a quilting pin to unclog them (a quilting pin is 2" as oppsed to a sewing pin which is 1.25").
yeah a lot of times they just go to shit and when pins no longer unclogg them go to a local junkyard and steal everyone u can find5th gens fit the same too. ihave like 50 sets lol. but if you want there $20 at honda for the set, and yes thats color matched.
Originally posted by brownaznkid i have that problem... mine arent clogged because when the hood is open, they work fine... so i traced the hoses, and it was being pinched by the hood hinges... so i have to relocate the hoses..
That little accordian piece located near the hinge goes bad and will pinch when you close the hood.
TBILL
92 Accord EX Coupe
CB7, 5 spd, Seattle Silver
