43 Code
    43 Code
    At this rainy morning i was at the freeway at 70mph and the check engine light comes on :s.
    Only at high speeds goes on, 55 mile up and more than 25 seconds at same rpm's
    The code i got is the 43
    ->Fuel Supply System
    Defective or malfunctioning fuel supply system
    i know could be a lot of things but some one have an idea what could be the problem.
    Note: yesterday i put away my Cat. Con.
    91 f22A6
    did you think this could be the reason for the check engine light.
    Thanks for the help
    Razer.-
    Rev rev rev
    check your o2 sensor, A LOT of time code 43 usually happens to be an faulty oxygen sensor, check it out.
      reason
      The reason was, that i put away the cat conv. and this thing keeps some temperature for a good and well o2 work; in the freeway the o2 get's more cold just a few grades, but thats enought to don't work fine.
      Razer.-
      Rev rev rev
