h22 bore?
    h22 bore?
    I have heard mixed results... but do most machine shops have the abbility to bore the h22 block?
    I think i am gona have to do a rebuild and their may be some wall scarring... i need to know if it can be bored to
    88mm or 88.5.....
    or if another block must be arranged...?
    i have heard most shops are scarred to do work on FRM sleeves...
    "Self Renewed"
    i actually wouldn't TRUST boring out and FRM-sleeved block... SPECIALLY if that much
    another block isn't necessary, but i would recommend sleeving for sure.
    THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
    My Ride thread
    Flickr
    Originally posted by d112crzy
    And it can only get better. That's the best part.
    All I gotta really say is:
    People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
      i dont think you can bore that much over frm. i know there is a special way to just hone the frm sleeves.
      i think 87.5mm and above is gonna require sleeves.
      So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
        just need to get the hone pattern and angle correct.
          THe problem is that after a certain amount of material has been taken off the sleeves are worthless.
          Some shops have the ability to hone FRM sleeves. I HIGHLY doubt you can bore it out to 88mm tho.
          Ask shops around. If they know anything about porches, then I'm sure they'll more than likely be able to bore out your FRM H22 sleeves.
