How Do You Change Or Swap Taillights In And Out
Help Please
What quickangel93 said, plus disconnect the electrical connectors by pushing down on the locking tab. You will need a deep well socket.Originally posted by 90HONDAINSPIRE View PostThe Entire Assembly
"The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
2 ways...Originally posted by 90HONDAINSPIRE View PostHow Do You Change Or Swap Taillights In And Out
Search
or
Open the trunk, look at the existing lights, find the (4) 10mm bolts on each and un-screw. Remove the light bulbs, Remove the old lights, put the new ones in, replace the bulbs then bolts, and VOILA!
