Main Bearing journal chipped
    Ok, So, i live where this engine block is,
    http://cgi.ebay.com/ebaymotors/Honda...mZ370141447359
    the center 3 journals are chipped, and they are selling it for 695 sleeved already, do you think these chips in the journals could effect the engine ?
    _____________________________
    91 Accord F22B
    that's very questionable...
    you can either tig weld that, resurface the main cap surface and re-alignhone it. but running it as-is might lead to the bearing flexing back and forth at those cracked edges which in turn fuck with your clearances.
    would i use it for a back up motor? probably...
    yould i use it for my primary motor which im going to spend a couple thousand dollars in parts and labor? nope...id rather spend the extra 400 and get a block re-sleeved, decked and honed.
      ^^^perfect answer thank you.
      91 Accord F22B
