ok, so i was driving home from the junk yard about 2 weeks ago and i felt my car just start slowing down, (felt like i took my foot off the gas) but i didnt, so any ways when it started doin that the engine light would dimmly blink, and but when i came to a red light, and started goin the car acted like it wanted to shut off, but idled fine. so i got almost home and the ignition switch started smokin. so i quickly shut the car off and took the cover off, and felt the wires and the main power wires were real hot and burnt lookin. i decided that my ignition switch was bad so tryin to hurry so i can get home, i cut the wires to it and basically hot wiresd the car so i can get home, but once i got it started again i started to leave if was sputtering bad when i tried to go. but it was so bad i couldnt move an inch and finally if just wouldnt start. so i got it towed to my house and i replaced the ignition switch with the one in my other cb7 and i also changed the little box that all the fuel injectors connect to. and it started and ran fine for a while till today it started to sputter again and i felt the wires and they started to heat up again. i think i have a wire grounding out but dont kno where to start. i unplugged the whole engine harness and when i touch the battery cable to the terminal it sparks, with everything off). i need help plzz. i have another cb7 so i dont plan on having this car long i just need it to get me to school and back.
thank you , any info will help.
