Ok I found another gremlin wrong with my 500 dollar jewel. When the car is turned off and doors open the driver side door wont lock. Like the little knob wont go down. But when the car is on and the doors are closed the lock will go down. I cant figure out whats causing this and I dont wanna take out the door panel if I dont have to. Anybody have this problem or ever experienced it?
Driver door wont lock
i don't know about sedans or wagons but on my coupe when the car is off and the door is open i can't lock it manually with the door open.Originally posted by Shag Wagon View PostOk I found another gremlin wrong with my 500 dollar jewel. When the car is turned off and doors open the driver side door wont lock. Like the little knob wont go down. But when the car is on and the doors are closed the lock will go down. I cant figure out whats causing this and I dont wanna take out the door panel if I dont have to. Anybody have this problem or ever experienced it?
if i close it, it works.
Yes my name is Dang, Don't use in vain
1992 Honda Accord EX (Coupe/Bordeaux/Auto)
1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
2008 Honda Accord EXL (Coupe/SanMarino/6spd)
Just wanted to let you know that you can lock that door without the key. Hold the inside door latch all the way out, and hit the lock tab down. It will lock all doors. I do it every time I leave the car!Originally posted by Shag Wagon View PostOk I just found out earlier I have to lock with the key on the outside!!! None of my wagons done it.......
i believe we have a winner! you can also pull the outside handle and push the button as well!!Originally posted by nine_deuce View PostI believe it's a safety feature so you don't accidentally lock your keys in your car??
