Road noise/Alignment question.
    Ok, my car needs an alignment....slight pull to the right. The tires are basically new but when I drive obviously hear a noise(sounds like road noise) but when I turn the steering wheel right to change lanes or if I'm going around a right curve or corner the stop automatically stops when I begin to turn the steering wheel to the right.
    Can someone give me some insight on this?
    1993 Accord LX - Sold
    93 BMW 525it - SOLD
    92 Accord EX Sedan - SOLD
    2000 Accord Coupe - Traded-In
    2003 Accord V6 6spd Coupe - Sold
    2001 Honda Civic Ex - SOLD
    2013 Chevy Traverse LTZ - Kid hauler
    2003 Acura Tl 3.2 - Daily Commuter
    sounds like your alignment could be off causing more friction=more noise or possible wheel bearing (usually sounds like a hum)
      not wheel bearing....got them changed right after i purchased the car.
      93 BMW 525it - SOLD
        bad tire/low psi/alignment?
          the psi was low so last week I inflated all tires correctly but it still made the same noise.
          As for bad tires, i wouldnt even know which one would be bad, they are fairly new.
          I'll rotate the tires and see but I think its the alignment but im not sure hence the reason i'm asking for input.
          93 BMW 525it - SOLD
