Don't know what happened, but all of a sudden my H22 started running rough. The idle is okay (not great), but from about 1000-3500 rpm, the engine stumbles as if the timing was off. I checked the cam timing and the ignition timing, and all is good. The entire intake manifold has been thoroughly cleaned recently since failing smog due to EGR, so I know airflow to the engine is good. What else should I look at?
Stumbling Engine
I did pass smog. HC's were okay, and I got the car dyno'ed a few months back before the swap. A/F looked okay back then. Anyway, the problem was the plugs. I assumed earlier that they were good because they were less than 5,000 miles old. Now I need to figure out what causing them to foul out (dry foul). I think the easiest answer is that I'm running rich, but the dyno and the lack of HCs go against that thought. What else should I check? Thanks.Originally posted by wed3k View Postso u did pass smog?
if you are running rich then the HC's on the smog paper will tell you. usually spark plugs will tell you too.
P13. Engine is completely stock except for intake and exhaust.Originally posted by wed3k View Postwhats your ecu?
