Dizzy leak
    Dizzy leak
    The ole sedan is leaking oil at the dizzy...more like puking. I have replaced the o-ring and it still leaks. I thought it was a defective o-ring so I went and bought another one and once again still pukes. It leaks right where the dizzy bolts to the block. What the hell is going on?
    Is it tighten good?
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Very tight. I have taken it on and off about 5 times looking and figuring it out. I finally got some engine degreaser and took off the dizzy and the back of the dizzy is clean. So I am thinking its the internal seal thats bad and its leaking from that little hole on the bottom of the dizzy.
        I suspect that as well. They 2 seals , outer and inner.
          Yea I finally got my hands on a mirror and the oil is definately coming out of that little hole. Time for a new dizzy or if anybody has a housing I can get.
            Ebay dud: $111.14. thats what i got. The inner seals are leaking also.
              Ooo! Get that thins replace before it burns the ignitor and make you stranded.
                jeenrus
