ok well i have a manual radiator in my car now found a crack in the top so im going to replace it. i have a brand new auto radiator that i use to have in my car when it was an auto but it has those tranny coolant lines at the bottom. should i have to plug those and with what? thanks for your help
real quick question about radiator need help fast
That makes no sense to me. Explain your logic be hind that please.Originally posted by wed3k View Postthe air within the tranny cooler needs to circulate in order to keep the coolant fresh and cool.
"The Turtle"
DD/Trail Rig/Mud Bug
I think you misunderstand how the transmission fluid cooler works.Originally posted by wed3k View Postthe air within the tranny cooler needs to circulate in order to keep the coolant fresh and cool.
Inside the bottom rad tank is a coiled up length of tubing through which the trans fluid is pumped, losing heat into the engine coolant as it does so (I know the coolant isn't particularly cool, but it's colder than the trans fluid because auto boxes are inefficient and can get very hot, which is why conventional auto boxes use more fuel).
There is no air flow specifically or directly involved with cooling the trans fluid, but ultimately the heat is lost through the rad fins via the coolant. There is absolutely no need to block, loop (or whatever) the trans fluid tubes if they aren't being used, it has no affect one way or the other on the cooling system when the 'auto' rad is used in a manual car. Just ignore the tubes altogether.Regards from Oz,
John.
i was just joking.Originally posted by johnl View PostI think you misunderstand how the transmission fluid cooler works.
