How many of you guys are running Synthetic oil, and have leaking seals? Since i switched, i have had to put 1QT per week in because its comin out the timing cover seal. I replaced the front balance shaft seal, cam and crank seal, yet its still leaking. Any idea's?
FYI, I ran Mobile1 10W30 Synthetic, leaked the most, put in 10W30 Semi synthetic and the leaking droped a bit, but its still leaking.
I dunno wtf's causing this, but it sure it ticking me off with the nice oil stain on the driveway.
I pressed them in pretty much dry, wiped everything down with a rag, and poped in the new one.
perhaps it works because of the tight tolerance, but still. maybe a TINY bit of oil just to rejuvinate and clean the rubber, and then wipe it back off? or something.
i also always use hondabond on the cam gears, but those are easy to put in either way.
