relay issue?
    relay issue?
    ok so i stumble downstairs to my pretty cb7 and lo an behold it wont start...nothing works it doesnt crank.. the batterys charged..the only thing that works is the hazzards and the horn and they work fine..i was thinking a relay?...maybe ignition switch?..anybody ever had that happen?
    But I'm still payin, so she still a ho. Why don't i just give her the money I was gonna spend on dinner, and that ho can get some groceries
    Did you fall down the stairs while you were at it? j/k
    I vote for ignition switch. If it was relay , it would crank.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      i almost did fall actually...it was a good morning..lol..but anyways wouldnt the lights still work if it was ignition
        It's a possibility it's the switch BUT , it could be your starter also. Try giving the starter a good tapping to see if it works.
          When you say "nothing works" are you meaning, no lights, no cluster, no nothing?
          Check the fuses? that's odd that nothing works
            yeah like NOTHING works but the horn and the hazzards..whcih i assume are just wired seperately for emergency purposes.. but yeah i mean like absolutely dead.. theres not even an attempt of anything to turn on..no noise no nothing...
              so seriously nobody else has run into something like this?
