H22 Problem
    H22 Problem
    My friend has a 93 prelude (260k mi. on car 60 on engine) with h22, n its been bugging the crap out of me.
    It started bogging out, the car idles fine, vtec's fine boggs out in pre-VTEC range, any quick sugestions before i start tearing it up?
    Originally posted by zack_odom
    Yummmmm. I'm going to go eat some Buddy Club sauce with my Mugen Spoon.
    are you air hoes running right??? i might have spelled that wrong.
    http://www.cb7tuner.com/vbb/showthread.php?t=139263
      the hoes are in check
        when i first did my swap all my hoes were mixed up and it wa choking at 4k rpms
          it only does it when its warmed up, its basically intermitten, its a fucking champ when its cold,
          the funny thing is, the engine looks like it belongs there, every little thing is in place, did they have h22s in 93?(Edit, Alldata says the option is available from 93 up, idk about US tho)
            well its not the fuel pump, fuel filter, or rotor cap and wires lol, its gotta be either electrical or a sensor
              mine does the same thing , only occasionally, but i think my problem could be the fuel filter or my egr ports which i need to clean >_> since i am getting horrible MPg
              -1992 CB7 EX w/H22 [sold 10/09]
              -2005 Legacy GT limited [current]
                it cant be the fuel filter, and it does it once in a while but its getting worse n worse, the egr actually wouldnt cause that problem, ive been surfing alldata, and it could be a ton of sensors(mostly on intake mani) but i dont have a multimeter for most of the procedures
                  I had wires rubbin on the fire wall check ur vtec wire. u can c if the vtec works by puttin a hot wire on it.
                    the problem occurs pre-vtec
                    OBD1 H22A Checklist:
                    Misfire/Rough Running
                    1. Fuel Injector
                    2. Fuel/Fuel Pressure Regulator
                    3. Manifold Absolute Pressure (MAP) Sensor
                    4. EGR Valve
                    5. ECU
                    Fail Emissions
                    1. Three Way Catalytic (TWC) Converter
                    2. EVAP
                    3. a.Fuel Pressure Regulator
                    b. Fuel Injector
                    4. MAP Sensor
                    5. Heated Oxygen Sensor (H2OS)
                    6. ECU
                    LOSS OF POWER---MOST Important One
                    1. a. Fuel Filter
                    b. Fuel
                    c. Fuel Pump
                    d. Injector Resistor
                    2. Throttle Position Sensor (7)
                    3. Air Intake System
                    a. Throttle Body
                    b. Intake Control System
                    4. Emission Controls - Cat.
                    5. Fuel Injectors (16)
                    6. MAP Sensor (5)
                    7. VTEC Control Solenoid Vavle
                    8. VTEC Pressure Swtich
                    9. ECU
                    I was bored
                      I got two suggestions, if his is internal coil, check the coil to see if still okay. Those things are really weak compared to the external coils. Another thing you could do is, has the TPS sensor ever been messed w/? b/c that can cause those problems if adjusted incorrectly. It should be .5 at idle and 4.5v at WOT.
                        Mostly everywhere else except for the USA. Everywhere else that had RHD Hondas: Japan and Europe etc. Preludes had H22s as early as 1992. The CB7model started in 1989 and ended in 1992 in Japan. We were basically one year behind with certain Honda models. If you see a 1993 on Alldata, it's more likely talking about the 5th gen CD chassis.
                        I need a custom turbo manifold built....
                        707 NorCal NinjaZ
                        Honda Twincam Motorwerkz?
                        "I am the Yakuza CB7!"
                        '92 Accord Sedan SiR
                          the tps got changed but its ebay, it still read at .5 tho
                            have u check ur knock sensor bc mine did that bogged adn hesitated b4 hittin vtec?
                              it did it before vtec, then it did it all over the range, n now it barelly runs
