ok so i changed my fpr fuel filter and o2 sensor and the code still persits it is kinda intermintent like highway when im at like 3000 rpms or in 4th crusing at low rpms or when i hit about 4500 in 3rd any body have any insight
code 43 drama
code 43 drama
member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973Tags: None
yeah i do ill try that out then
nope still throws the code im wondering if its the fuel pump
already replaced the o2 fpr and fuel filter and tried a different ecu yeah it is so irritating lol but if its a fuel pump it would probably cut off and shit right???
any ideas??
yeah pretty much all i did needed to be done anyways lol so fuel pump it is dammit
ya ive done everything on that but check voltage on the ecu itself ill try that next thanks ill have to save that
what kinda o2 sensor you got? you can test the voltage easy on the ecu by take the backing plate off the back and the soder points are in corrospondence with the mysterious "test harness" no one can get ahold of. This lets you test the voltage with te ecu still hooked up._____________________________
91 Accord F22B
