no idle when warm?
    no idle when warm?
    i have a stock rebuilt f22 with a Delta 272 and MRX chipped p06 with a basemap 272.
    when the car is cold, it will start fine and idle at 1000.
    once it warms up, it wont hold idle whatsoever. it will run fine with a vacuum leak. i had the cam timing at zero and at advanced 4 degrees
    Idle needs to be adjusted? still running FITV?
    wat?
      FITV has no coolant lines attached.
      the idle adjustment screw doesnt affect it whatsoever which i find wierd.
      IACV = 12.7 ohms
      the white coolant temp sensor = 271 ohms when warmed up.
      TPS set properly
        IF you have no coolant line to the fitv you should make a block off for it imo.
        wat?
          why cant i just run it with no coolant lines?
            You can. We have an armchair quarterback in this thread.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              that term lost me.
                that term lost me.
                What I meant was, I don't think that guy has any first-hand experience with bypassing coolant lines on the FITV.
                Gary A.K.A. Carter
                  idk but im really open to ideas since the auto-x is on sunday and i kinda dont like vacuum leaks especially its the only way the engine can idle at the moment
                  forgot to add that the spark plugs are pretty dark but i think the rich issue was fixed when i advanced the cam timiing. i havent really fucked with ignition timing since i cant get the car to idle. i need to borrow an advanced timing light so i can set the advance.
                    sounds like a functioning FITV but non functioning IACV but
                    the idle screw not affecting it
                    idle screws ports blocked cause of being dirty, but I don't think you would have left that off in your rebuild.
                    ____
                      i dont think it is any of those components any more. i think its getting too much fuel at idle...and/or maybe when running?
                      im going to put a fuel pressure guage and see what the psi is...maybe the regulator is corrupt?
                      i know the injectors all tested within 2-3ohms however they were off another car. i put new seals on them and there's no fuel leaks.
                      stock fuel pump..
