fuel pump fuses keep blowing
    and its pissing me the fuck off i just changed the fuel pump, timing belt, dizzy cap, wires, valve adjustment today and i just went to take a drive and i drove about a mile then my car just shut off so i check and my fuel pump fuse was blown and i replace it and the second i turn my key my dash lights flicker reallly fast then i hear the fuse blow i know its probably a short in the wire but after i blew 2 fuses i put like 4 more in and they did the same thing
    my question is has anyone had any similar problems and where should i look for the short at? where is the wires from the fuse box routed to the fuel pump?
    any help is appreciated
    to achieve a Fuck, you must first give a Fuck
    Follow me on twitter @tru_whitetrash
    You will have to break out the test light and check for shorts. Do you know what the fuse number is?
    "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
      not sure bro i havent had a chance to look im at home and my car is broked down in huntington
        Here's a wiring diagram to help with the diag.
        If I had to guess, I would say the short is at the fuel pump connections. But that is just a guess. You're still going to have to diagnose.
