Ok my power steering fluid has bubbles in it and it shoots out of the resavor! what could this be ?
bubble is power steering fluid resavor!
My car did the same thing. It also squeaks/moans/groans in cold weather. 'Bleeding' it by topping off the fluid and turning it from lock to lock cures the problem, at least for the short term.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
really i couldnt get rid of it, tried to find leaks and everything. found out my pump was leaking so i got it rebuilt for like 50 bucks...
now its all good.
just check for leakk everywhere if u cant see em wash the engine and also feel the steering rack boots...if they have fluid in it then you know whats up.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Hey peeps i had the same problem as well, Im not too good with cars myself but i saw the mechanic replace this rubber seal, i think the powersteering motor? or the pump? it was near the PS reservoir tank, then i told him i had that moaning/whale sound, and he said it was because the powersteering belt or something wasnt tight? so he adjusted the belt near the ps reservoir tank and now its all good. No more bubbles foaming up and no whale sound.
Hope that helps?
