A/C Diagram
    A/C Diagram
    Ive looked all over for it and cant find one.
    I need a diagram for how the A/C unit runs through an F22A4. Im having problems with it and i want to check some stuff on it and refill it which i think i need to but i have no idea where to start on it.
    If anyone has a diagram or can find one for me or give me any info that would help i would greatly appreciate it.
    Diagram as in what?
    Electrical?
    or Parts?
      Originally posted by JaK FRoSTWhiTE View Post
      Diagram as in what?
      Electrical?
      or Parts?
      both.
      i need everything i can possible get on it
        Whats wrong with your AC?
          It doesnt blow cold. It turns on and everything runs it just doesnt blow cold at all. I know nothing about the A/C and dont know where the lines run.
          I was told it just needs to be recharged or refilled or whatever but i dont know what im looking for in the car to even do that
            if you dont know anything about the A/C i suggest you actualy take it to someone who knows, dont want to be messing around with the A/C, pretty dangerous. plus it seems like all u need to do is clean your system out and recharge it with new fluid
              It seems you dont know anything about the A/C system.
              Is your A/C even converted to R134a?
              My advice would be for you to take it to a Honda dealer and pay the A/C Diagnostics fee.
              They will charge the system, add a dye, and test it for leaks.
              If it does have a leak they will tell you where it is (Then it will be up to you if you want them to fix it, or for you to do it)
              If they cant find a leak they will charge it for you and tell you to bring it back when it starts blowing warm again.
              Like that the dye can actually run through the system.
              Depending on your local Honda Dealer's shop rate it should be between $89.99-119.99
              If i were you, thats what i would do.
                well i wasnt planning on changing or replacing anything. the most i would do is recharge it myself and i know people who can help me with it but i was gonna try and find some stuff out on my own first.
                well i dont got that kind of money and i was planning on getting on of the adaptor kits from walmart people on here have been talking about. i dont think i have a leak tho cuz ive taken it to the shop twice and every time they tell me it is fine there are no leaks or anything but they never tell me i need to recharge it
