Question about A/C and fan.
    Okay couple months ago my A/C was working but needed an A/C recharge because its not that cold. Well now the weather is hotter i turned on my A/C and it blows hot air and so i noticed that my A/C fan isn't kicking on either. Anyone have an idea what causes of this? Both rad fan and A/C fan kicks on when engine is hot though so i don't think the A/C fan is broken. Anyone have any input?
    CD7 H22
    CB7 H22
    FROST WHITE CREW #33
    Member's Ride Thread
    Cardomain Page
    A/C clutch kicking on? If you needed a charge a few months ago, your 134a has probably leaked out again. The condenser fan sometimes wont come on without the A/C clutch engaging.
      Pressure in side your a/c system is not high enough to engage the pressure switch, aka you have a leak.
      wat?
        Thanks guys! So how do i know if my A/C clutch is engaging?
        CD7 H22
        CB7 H22
        Cardomain Page
          Pressure could be too high. Since the higher temps we are having now. Your high side pressure has gone up if it goes up too high compressor won't engage.
          I filled my wifes altima about a month ago because it wasn't cold enough, never checked high side pressure just added then when it got hot the pressure got higher and AC blew hot air.
          steve
          Check out ackits.com
            while your A/C is on look under the hood by the A/C compressor to see if the wheel pulley is spinning if it's not spinning that means the clutch is not engaged. To test it run a power source to the wire and turn on the A/C if it comes on then you know the clutch is good but there's a problem with it engaging on it's own.
