Ok so this happened today while driving. Earlier in the day I saw (when applying brakes) my needles jumped a little. After a while, the voltage started to drop. The voltage has been just under 14v, all of a sudden it went down to 11.7 then down to 9, then 8. Of course it begins to pour down rain - wipers barely work, windows barely open/close, headlights bring it down below 8v. I made it home, nothing caught on fire.
So could this still be the ignitor, or could it be something else? Everything has been fine, I just had my alternator tested and it's fine. It's not the VSS, battery is good, wiring is solid, grounds are clean and tight, belt is tight.
EDIT: If I'm to replace the dizzy, I can buy the usdm h22a1 dizzy right?
