Ok can i do this instead of....
    Ok i read the abs removal thread, and dont wanna go out and get the other stuff i just want to remove it, and mines doesnt work anyway so cant i just remove the abs thing in the engine bay and be done with it?
    If you want to remove your ABS system you have to buy the Non ABS brake lines and a 40/40 proportioning valve. There is no way around it.
    It is not that expensive. I paid $20 for the 4 brake lines and $35 for the prop valve. Trust me it is worth it if your ABS system is not working.
      ok i guess i will...
        Here is the DIY
        http://www.cb7tuner.com/vbb/showthre...&highlight=abs
        It helped me a lot.
        The only complicated thing is if you want to use your ABS master cylinder you will have to change over one of the fittings from your old lines. You will have to use a double flare tool to re-flare the line. It is not hard, but it is a little bit of a PITA.
        Good luck!
