Hey guys it me again I been searching the f22a6 Mani swap I dont understand a thing. This what Im doing I have a 1991 Honda Accord LX with blown engine Im bout to buy a 1993 Honda Accord EX f22a6 been hit in the side pretty Hard Im planning on swaping the engine in my car and ECU What do I do please Help Thanx CB7 Brothers
Swaping
follow this guide and pull both motors: http://www.cb7tuner.com/vbb/showthre...&threadid=8849 the guide covers pulling a manual motor, so do your dead one first to get a feel for whats going on, then you will need to improvise a bit when pulling the automatic one.Originally posted by DG Accord
My Car is a 5speed the car Im getting engine out of is an Auto
when they are both out, set them side by side and anything different between them (related to being automatic or 5spd), swap onto the new f22a6... things i can think of off the top of my head to swap from ur dead motor to the new one: flywheel, clutch, pressure plate, tranny, wiring harness... also recommended: install a new water pump and timing belt (refer to the manual)
refer to a Chilton's manual for pulling off the transmissions and whatnot, it explains pretty well. if you follow it correctly you wont have a problem bolting the old transmission onto the new motor
then follow that guide in reverse to put the motor back in.
its easier than you think, youll just need to put the time and effort into it, and you need to actually take the time to look things up online and in the manual.
good luck with it, we have tons of info and will be here to help you at any point of your swap
