Why do Vss die out so much??
    If your car doesnt have any power steering fluid in it will the Vss stop working Im trying to figure out why ive went through 4 Vss in the last 6 months
    i got one FS if u need it also in my thread
    Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
    CLICK THE PIC
      ive never had one go out
      oh and no, powersteering fluid has nothing to do with the vss.
      smoke tires, not drugs.
        you don't have a coolant leak do you? I had one right where the pipe meets the T stat housing behind the block, and it was dripping on that when i was driving causing it to short out sometimes.
          thank man but no sense in buying anuda one I gotta find out why they keep shorting out or whatever
            are you using oem or aftermarket?
            if its autozone parts, i would take them off and try an oem one and see if it is the issue.
              Oem allday
                Oem allday
                hmm...and youve checked the wiring isnt frayed or anything?
                have you tried just replacing the cluster? maybe thats the issue and not the vss.
                  whats those lines that run to it for then
                    getting tha s light
                      Those lines go to the power steering speed "sensor." This is to control power steering fluid pressure, so that it increases when the speed of the vehicle is low and decreases when the speed is higher.
                      "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
                        might actally be a grounding issue. check the ground that goes to the thremostat. later.
                        Avoiding dirt at all costs
                          if that was the problem, wouldnt other things act kinda funny too?
                            the one you gave me with the swap, never worked. idk y
                            miss my turbo cb7
                              will the sensor stop working if the grease stuff on the inside ? all so if the dizzy is leaking oil on to the connector?
